27-Command Index
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9119-6W10027-Command Index
27-Command Index
Title Size Downloads
27-Command Index-book.rar 11.17 MB
Table of Contents
Related Documents
book
book 11.17 MB
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa authorization
aaa authorization
aaa device-id
aaa nas-id
aaa nas-id profile
aaa nas-id-profile
aaa session-id mode
aaa session-limit
aaa-fail nobinding enable
abr-summary
abr-summary
ac interface
accelerate
accept target-hello
accept-label
accept-lifetime
accept-tolerance
access-limit
access-user email authentication
access-user email format
access-user email sender
access-user email smtp-server
accounting advpn
accounting command
accounting default
accounting lan-access
accounting login
accounting portal
accounting ppp
accounting start-fail
accounting update-fail
accounting-on enable
accounting-on extended
ack-flood action
ack-flood detect
ack-flood detect non-specific
ack-flood threshold
acl
acl copy
action (IPS policy view)
action (IPS signature view)
action cli
action reboot
action switchover
action syslog
activation-key
active region-configuration
additional-paths select-best
address
address
address
address range
address range
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
address-family ipv4 flowspec (BGP-VPN instance view)
address-family ipv4 flowspec (VPN instance view)
address-family ipv4 mdt
address-family ipv4 mvpn
address-family ipv4 tnl-encap-ext
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (VPN instance view)
address-family ipv6 flowspec (BGP-VPN instance view)
address-family ipv6 flowspec (VPN instance view)
address-family ipv6 sr-policy
address-family l2vpn
address-family l2vpn evpn
address-family link-state
address-family vpnv4
address-family vpnv4 flowspec
address-family vpnv6
address-family vpnv6 flowspec
advantage-factor
advertise application link-attributes
advertise ebgp enable
advertise l2vpn evpn
advertise link-attributes
advertise route-reoriginate
advertise srv6 locator
advertise-definition enable
advertise-label
advertise-rib-active
advpn group
advpn ipv6 network
advpn logging enable
advpn map group
advpn network
advpn session dumb-time
advpn session idle-time
advpn source-port
advpn-domain
affinity exclude-any
affinity include-all
affinity include-any
affinity-map
aft address-group
aft alg
aft enable
aft log enable
aft log flow-begin
aft log flow-end
aft port-block flow-trigger enable
aft prefix-general
aft prefix-ivi
aft prefix-nat64
aft turn-off tos
aft turn-off traffic-class
aft v4tov6 destination
aft v4tov6 source
aft v6server
aft v6tov4 source
agent-type
aggregate
aging-time
ah authentication-algorithm
alarm-detect
alarm-detect
alarm-detect
alias
allocate core
ams
analyzer
analyzer id
anycast enable
anycast-rp (IPv6 PIM view)
anycast-rp (PIM view)
append
app-id (Facebook authentication server view)
app-id (QQ authentication server view)
app-key (Facebook authentication server view)
app-key (QQ authentication server view)
application-quality
apply
apply access-vpn vpn-instance
apply continue
apply continue
apply default-next-hop
apply default-output-interface
apply default-srv6-policy
apply ip-df
apply loadshare
apply loadshare
apply next-hop
apply next-hop
apply output-interface
apply precedence
apply precedence
apply remark-vpn
apply remark-vpn
apply srv6-policy
apply srv6-policy
archive configuration
archive configuration interval
archive configuration location
archive configuration max
archive configuration server
archive configuration server password
archive configuration server user
area
area
area-authentication send-only
area-authentication-mode
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection log enable
arp detection port-match-ignore
arp detection rule
arp detection trust
arp detection validate
arp distributed-gateway dynamic-entry synchronize
arp fast-reply enable
arp filter binding
arp filter source
arp fixup
arp ip-conflict log prompt
arp ip-unnumbered learning enable
arp mac-interface-consistency check enable
arp mac-learning disable
arp max-learning-num
arp max-learning-number
arp mode uni
arp pnp
arp proxy-send enable
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp route-direct advertise
arp scan
arp scan auto enable
arp scan auto send-rate
arp sender-ip-range
arp send-gratuitous-arp
arp snooping enable
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp static
arp suppression enable
arp timer aging
arp user-ip-conflict record enable
arp user-move record enable
arp valid-check enable
asbr-summary
asbr-summary
ascii
as-path-limit
attack-category
attack-defense apply policy
attack-defense local apply policy
attack-defense login reauthentication-delay
attack-defense policy
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attribute
attribute 15 check-mode
attribute 25 car
attribute 30 mac-format
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute vendor-id 2011 version
attribute-map
authentication advpn
authentication challenge
authentication default
authentication ike
authentication key
authentication lan-access
authentication lifetime
authentication login
authentication portal
authentication ppp
authentication super
authentication window-size
authentication-method
authentication-mode
authentication-mode
authentication-mode
authentication-server
authentication-timeout
authorization advpn
authorization command
authorization default
authorization ike
authorization lan-access
authorization login
authorization portal
authorization ppp
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
authorization-server
auth-url
auto-cost enable
auto-discovery
auto-discovery
auto-execute command
autoroute enable
autoroute metric
auto-rp enable (PIM view)
auto-tunnel backup
B
backoff
backup hot-standby
backup interface
backup startup-configuration
backup threshold
backup timer delay
backup timer flow-check
backup track
backup-opcode
backup-peer
backup-peer
balance
balance as-path-neglect
balance as-path-relax
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth-reference
bandwidth-reference
bandwidth-reference
basic-service-ip-type
bestroute as-path-neglect
bestroute compare-med
bestroute encap-type
bestroute igp-metric-ignore
bestroute ipv6-nexthop
bestroute med-confederation
bestroute router-id-ignore
bfd all-interfaces enable
bfd authentication-mode
bfd demand enable
bfd detect-interface
bfd detect-multiplier
bfd discriminator
bfd echo
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd enable
bfd ip-router-alert
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bfd static
bfd template
bfd trigger path-down enable
bgp
bgp update-delay on-startup
bgp update-delay on-startup ipv6-prefix-list
bgp update-delay on-startup prefix-list
bgp update-delay wait-other-protocol
bgp-policy
bidir-pim enable (IPv6 PIM view)
bidir-pim enable (PIM view)
bidir-rp-limit (IPv6 PIM view)
bidir-rp-limit (PIM view)
binary
bind interface
bind-attribute
binding-destination
binding-retry
binding-sid
block-size
bmp server
bootfile-name
boot-loader file
boot-loader update
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
bundle id
bundle load-balance
bundle max-active links
bundle member-priority
bundle min-active bandwidth
bundle min-active links
bye
bye
bypass
C
ca identifier
cable (CE1 interface)
cache list
cache source-address
cached-data
cache-limit
cache-sa-enable
candidate-paths
capability default-exclusion
car
car percent
card-mode
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
ccc
cd
cd
cd
cdup
cdup
certificate domain
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
certificate-chain-sending enable
cfd ais enable
cfd ais level
cfd ais period
cfd cc enable
cfd cc interval
cfd dm one-way
cfd dm one-way continual
cfd dm two-way
cfd dm two-way continual
cfd dm two-way threshold
cfd enable
cfd frame-count mode
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd port-trigger
cfd service-instance
cfd slm
cfd slm continual
cfd slm port-trigger up-delay
cfd slm threshold
cfd tst
cfd tst continual
cfd tst threshold
channel-set (CE1 interface)
check flow-route-configuration
check region-configuration
checkzero
checkzero
ciphersuite
circuit-cost
class
class ip-pool
class option-group
class pool
class range
classifier behavior
cli
client
client enable
client enable
client-authentication
client-authentication xauth user
client-verify
clock
clock
clock (CE1 interface)
clock datetime
clock protocol
clock summer-time
clock timezone
clock-change auto
close
cloud-binding enable
cloud-management backup-server domain
cloud-management keepalive
cloud-management ping
cloud-management server domain
cloud-management server password
cloud-management server port
cloud-management unbinding-code
cloud-server url
code (CE1 interface)
codec-type
collaboration peer local
collaboration peer redirect
collector
collector id
color end-point
color match dscp
command
command accounting
command authorization
commit
commit
common-name
community read
company
compare-different-as-med
confederation id
confederation nonstandard
confederation peer-as
config-exchange
configuration commit
configuration commit delay
configuration encrypt
configuration replace file
connection
connection remote-site-id
connection-limit
connection-limit apply
connection-limit apply global
controller cpos
controller e1
control-plane
control-word enable
control-word enable
copy
copyright-info enable
cost-style
country
cpu
cqi-weight
crc
crc
crl check enable
crl url
c-rp (IPv6 PIM view)
c-rp (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
customlog character-encoding utf-8
customlog format
customlog host
customlog host source
customlog timestamp
D
dampening
dampening ibgp
database-filter peer
databits
data-coding (CE1 interface)
data-delay
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-group
data-size
ddns apply policy
ddns dscp
ddns policy
debug
debugging
default
default
default
default
default
default
default
default
default
default cost
default cost
default ip-pool
default local-preference
default med
default pool
default tag
default-cost
default-cost
default-group
default-logon-page
default-pw-id
default-route
default-route imported
default-route update-first
default-route-advertise
default-send-key
delay
delay threshold
delay-measure disable
delete
delete
delete
delete dynamic-flow
delete ip rpf-route-static
delete ipv6 static-routes all
delete ssh client server-public-key
delete static-routes all
delete-delay
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (IPS whitelist entry view)
description (user-defined IPS signature view)
description (VPN instance view)
destination
destination
destination host
destination ip
destination ipv6
destination mac
destination-address
destination-group (subscription view)
destination-group (telemetry view)
destination-port
detect-ais
detection-integer
detection-keyword
device-id
dh
dh
dhcp apply-policy
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp dscp
dhcp enable
dhcp log enable
dhcp option-group
dhcp policy
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay forward reply by-option82
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay mac-forward enable
dhcp relay request-from-tunnel discard
dhcp relay server-address
dhcp relay source-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server database filename
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server reply-exclude-option60
dhcp smart-relay enable
dhcp snooping alarm enable
dhcp snooping alarm threshold
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check giaddr
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping client-detect
dhcp snooping deny
dhcp snooping disable
dhcp snooping enable
dhcp snooping enable vlan
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping information vendor-specific
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping trust
dhcp snooping trust interface
dhcpv6-follow-ipv6cp
diagnostic bootup enable test
diagnostic event-log size
diagnostic monitor action
diagnostic monitor enable
diagnostic monitor interval
diagnostic ondemand failure
diagnostic ondemand repeating
diagnostic ondemand start
diagnostic ondemand stop
diagnostic simulation
diagnostic start test
diagnostic-logfile save
dialer bundle enable
dialer callback-center
dialer diagnose
dialer disconnect
dialer flow-interval
dialer number
dialer peer-name
dialer queue-length
dialer route
dialer threshold
dialer timer autodial
dialer timer compete
dialer timer enable
dialer timer idle
dialer timer wait-carrier
dialer timer warmup
dialer-group
dialer-group rule
diffserv-mode
dir
dir
dir
direction
disable (explicit path view)
disable-dn-bit-check
disable-dn-bit-set
discard-route
disconnect
disconnect-mode
discriminator
disk
Display [ | [ by-linenum ] { begin | exclude | include } ]
display >
display >>
display 6rd
display 6rd destination
display 6rd prefix
display acl
display acl accelerate
display adjacent-table
display advpn group-qos-map
display advpn ipv6 session
display advpn session
display advpn session count
display aft address-group
display aft address-mapping
display aft configuration
display aft no-pat
display aft port-block
display aft session
display aft statistics
display alarm
display alias
display archive configuration
display arp
display arp detection
display arp detection statistics
display arp entry-limit
display arp ip-address
display arp openflow count
display arp pnp
display arp snooping
display arp source-mac
display arp source-mac statistics
display arp source-suppression
display arp suppression vsi
display arp timer aging
display arp user-ip-conflict record
display arp user-move record
display arp valid-check statistics
display arp vpn-instance
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense statistics interface
display attack-defense statistics local
display bfd session
display bgp bmp server
display bgp dampening parameter
display bgp egress-engineering ipv4
display bgp egress-engineering ipv6
display bgp egress-engineering peer-set
display bgp egress-engineering srv6 peer-set
display bgp group
display bgp instance-info
display bgp l2vpn auto-discovery
display bgp l2vpn evpn
display bgp l2vpn signaling
display bgp link-state
display bgp mirror remote-sid
display bgp network
display bgp non-stop-routing status
display bgp paths
display bgp peer
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 flowspec
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 mvpn
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 tnl-encap-ext
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 flowspec
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 sr-policy
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 flowspec
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 flowspec
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp segment-routing label-range
display bgp update-group
display boot-loader
display bootp client
display bundle hdlc-bundle
display cfd ais
display cfd dm one-way history
display cfd dm two-way history
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd slm history
display cfd status
display cfd tst history
display clock
display cloud-management state
display connection-limit
display connection-limit ipv6-stat-nodes
display connection-limit statistics
display connection-limit stat-nodes
display controller cpos
display controller cpos e1
display controller e1
display copyright
display core allocation
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto-engine
display crypto-engine statistics
display current-configuration
display current-configuration diff
display ddns policy
display debugging
display default-configuration
display device
display device manuinfo
display device manuinfo fan
display device manuinfo power
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding
display dhcp snooping binding database
display dhcp snooping drni-statistics
display dhcp snooping drni-status
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic bootup
display diagnostic content
display diagnostic event-log
display diagnostic ondemand configuration
display diagnostic result
display diagnostic result statistics
display diagnostic simulation
display diagnostic-logfile summary
display dialer
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display domain
display domain-sriov-vf
display dot1x
display dot1x connection
display ds-lite b4 information
display environment
display ethernet statistics
display evpn auto-discovery
display evpn es
display evpn instance
display evpn ipv6 auto-discovery
display evpn ipv6 route mac
display evpn route arp
display evpn route arp suppression
display evpn route mac
display evpn route nd
display evpn route nd suppression
display evpn route xconnect-group
display evpn routing-table
display evpn srv6 mirror remote-sid
display exception context
display exception filepath
display explicit-path
display fan
display fib
display flow-route
display ftp client source
display ftp-server
display ftp-user
display grpc
display history-command
display history-command all
display hotkey
display http-redirect statistics
display hwtacacs scheme
display ict mode
display ifit flow dynamic
display ifit flow static
display ifit global-information
display ifit instance
display ifit statistic
display igmp group
display igmp interface
display igmp proxy group
display igmp proxy routing-table
display igmp ssm-mapping
display igmp-snooping
display igmp-snooping group
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display ike statistics
display ikev2 policy
display ikev2 profile
display ikev2 proposal
display ikev2 sa
display ikev2 statistics
display info-center
display info-center filter
display inqa analyzer
display inqa analyzer instance
display inqa analyzer instance ams
display inqa collector
display inqa collector instance
display inqa interface
display inqa statistics loss
display interface
display interface
display interface dialer
display interface hdlc-bundle
display interface inloopback
display interface link-info
display interface loopback
display interface main
display interface mp-group
display interface null
display interface pos
display interface range
display interface register-tunnel
display interface serial
display interface tunnel
display interface virtual-access
display interface virtual-template
display interface vlan-interface
display interface vsi-interface
display interface-backup state
display interface-backup statistics
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip interface
display ip interface brief
display ip netstream cache
display ip netstream export
display ip netstream template
display ip policy-based-route
display ip policy-based-route global
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip pool
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip urpf
display ip vpn-instance
display ips policy
display ips signature
display ips signature library
display ips signature pre-defined
display ips signature user-defined
display ips signature user-defined parse-failed
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
display ipsec sa
display ipsec sdwan-sa local
display ipsec sdwan-sa remote
display ipsec sdwan-statistics
display ipsec sdwan-tunnel
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ipv6 adjacent-table
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping drni-statistics
display ipv6 dhcp snooping drni-status
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping pd binding
display ipv6 dhcp snooping trust
display ipv6 dns server
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast fast-forwarding cache
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 mrib interface
display ipv6 multicast boundary
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast rpf-info
display ipv6 nd user-ip-conflict record
display ipv6 nd user-move record
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors entry-limit
display ipv6 neighbors vpn-instance
display ipv6 netstream cache
display ipv6 netstream export
display ipv6 netstream template
display ipv6 pathmtu
display ipv6 pim bsr-info
display ipv6 pim claimed-route
display ipv6 pim c-rp
display ipv6 pim df-info
display ipv6 pim interface
display ipv6 pim neighbor
display ipv6 pim routing-table
display ipv6 pim rp-info
display ipv6 pim statistics
display ipv6 policy-based-route
display ipv6 policy-based-route global
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 router-renumber statistics
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 segment-routing sid-list
display ipv6 source binding
display ipv6 source binding pd
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 tcp-proxy
display ipv6 tcp-proxy port-info
display ipv6 udp
display ipv6 udp verbose
display ipv6 urpf
display isis
display isis event-log graceful-restart
display isis event-log lsp
display isis event-log spf
display isis flex-algo route
display isis flex-algo spf-tree
display isis global-flex-algo
display isis global-statistics
display isis graceful-restart status
display isis interface
display isis local-flex-algo
display isis lsdb
display isis lsdb statistics
display isis mesh-group
display isis mpls te advertisement
display isis mpls te configured-sub-tlvs
display isis mpls te network
display isis mpls te tunnel
display isis name-table
display isis non-stop-routing status
display isis packet
display isis peer
display isis redistribute
display isis route
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing ipv6 capability
display isis segment-routing ipv6 locator
display isis segment-routing prefix-sid-map
display isis segment-routing routing-table
display isis spf-tree
display isis srv6 tunnel
display isis statistics
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display keychain
display l2-multicast fast-forwarding cache
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display l2vpn auto-discovery
display l2vpn bgp
display l2vpn bgp
display l2vpn forwarding
display l2vpn forwarding evpn
display l2vpn forwarding evpn split-horizon
display l2vpn forwarding srv6
display l2vpn interface
display l2vpn ldp
display l2vpn ldp
display l2vpn mac-address
display l2vpn peer srv6
display l2vpn pw
display l2vpn pw
display l2vpn pw bfd
display l2vpn pw-class
display l2vpn statistics srv6-pw inbound
display l2vpn vsi
display l2vpn vsi
display l2vpn vsi
display l2vpn xconnect-group
display lacp system-id
display ldap scheme
display license
display license
display license client
display license client statistics
display license device-id
display license feature
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display link-flap protection
display local-guest waiting-approval
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile buffer
display logfile summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-authentication
display mac-authentication connection
display mac-for-vmminterface
display mac-forwarding cache ip
display mac-forwarding cache ip fragment
display mac-forwarding cache ipv6
display mac-forwarding statistics
display mac-vlan
display mac-vlan interface
display memory
display memory-threshold
display mgre session
display mirroring-group
display mld group
display mld interface
display mld proxy group
display mld proxy routing-table
display mld ssm-mapping
display mld-snooping
display mld-snooping group
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display mode channel-bandwidth interface
display mpls bfd
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp error-packet
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls lsp
display mpls lsp statistics
display mpls nib
display mpls nid
display mpls static-cr-lsp
display mpls static-lsp
display mpls static-sr-mpls adjacency
display mpls static-sr-mpls lsp
display mpls static-sr-mpls prefix
display mpls statistics tunnel-interface
display mpls summary
display mpls te ds-te
display mpls te link-management bandwidth-allocation
display mpls te p2mp tunnel-interface
display mpls te pce discovery
display mpls te pce lspdb
display mpls te pce lspdb last-packet-detail
display mpls te pce peer
display mpls te pce statistics
display mpls te tedb
display mpls te tunnel-interface
display mpls tunnel
display mrib interface
display msdp brief
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast fast-forwarding cache
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-vpn c-multicast routing-table
display multicast-vpn data-group receive
display multicast-vpn data-group send
display multicast-vpn default-group
display multicast-vpn neighbor
display nat address-group
display nat all
display nat dns-map
display nat eim
display nat eim statistics
display nat inbound
display nat log
display nat no-pat
display nat outbound
display nat outbound port-block-group
display nat port-block
display nat port-block-group
display nat server
display nat server-group
display nat session
display nat static
display nat statistics
display netconf service
display netconf session
display nhrp map
display nhrp statistics
display nqa history
display nqa result
display nqa server
display nqa statistics
display nqa twamp-light client
display nqa twamp-light client statistics
display nqa twamp-light client test-session reaction counters
display nqa twamp-light responder
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf event-log
display ospf event-log hello
display ospf fast-reroute lfa-candidate
display ospf graceful-restart
display ospf hostname-table
display ospf interface
display ospf interface hello
display ospf lsdb
display ospf mpls te advertisement
display ospf mpls te network
display ospf mpls te pce
display ospf mpls te tunnel
display ospf nexthop
display ospf non-stop-routing status
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf segment-routing adjacency
display ospf segment-routing global-block
display ospf segment-routing prefix-sid-map
display ospf segment-routing routing-table
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 event-log
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 non-stop-routing
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 segment-routing ipv6 capability
display ospfv3 segment-routing ipv6 locator
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 srv6 tunnel
display ospfv3 statistics
display ospfv3 vlink
display packet-capture status
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display password-control
display password-control blacklist
display pim bsr-info
display pim claimed-route
display pim c-rp
display pim df-info
display pim interface
display pim neighbor
display pim routing-table
display pim rp-info
display pim statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate renew-status
display pki certificate request-status
display pki crl domain
display port
display portal
display portal auth-error-record
display portal auth-fail-record
display portal dns free-rule-host
display portal extend-auth-server
display portal logout-record
display portal mac-trigger user
display portal mac-trigger-server
display portal packet statistics
display portal permit-rule statistics
display portal redirect session
display portal redirect statistics
display portal rule
display portal safe-redirect statistics
display portal server
display portal user
display portal user count
display portal user-block
display portal web-server
display port-isolate group
display power-supply
display ppp access-user
display ppp mp
display ppp packet statistics
display pppoe-client session packet
display pppoe-client session summary
display pppoe-server packet statistics
display pppoe-server session packet
display pppoe-server session summary
display pppoe-server throttled-mac
display pppoe-server va-pool
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display proxy-arp
display public-key local public
display public-key peer
display qinq
display qos car interface
display qos carl
display qos cql
display qos gts interface
display qos lr
display qos map-table
display qos policy
display qos policy advpn
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos policy user-profile
display qos pql
display qos queue cbq
display qos queue cq interface
display qos queue fifo
display qos queue interface
display qos queue pq interface
display qos queue rtpq interface
display qos queue wfq
display qos trust interface
display qos wred interface
display radius scheme
display radius statistics
display rib attribute
display rib graceful-restart
display rib nib
display rip
display rip database
display rip graceful-restart
display rip interface
display rip neighbor
display rip non-stop-routing
display rip route
display ripng
display ripng database
display ripng graceful-restart
display ripng interface
display ripng neighbor
display ripng non-stop-routing
display ripng route
display rir sdwan application-quality
display rir sdwan bandwidth tunnel
display rir sdwan flow
display rir sdwan link-quality
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display router id
display route-static nib
display route-static routing-table
display rsvp
display rsvp authentication
display rsvp lsp
display rsvp peer
display rsvp request
display rsvp reservation
display rsvp sender
display rsvp statistics
display rtm environment
display rtm policy
display sampler
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display scp client source
display sdwan peer-connection status
display sdwan server status
display sdwan site-tte
display sdwan tte connection
display security-logfile buffer
display security-logfile summary
display segment-routing ipv6 forwarding
display segment-routing ipv6 local-sid
display segment-routing ipv6 locator
display segment-routing ipv6 sfc forwarding
display segment-routing ipv6 te bfd
display segment-routing ipv6 te database
display segment-routing ipv6 te forwarding
display segment-routing ipv6 te policy
display segment-routing ipv6 te policy last-down-reason
display segment-routing ipv6 te policy statistics
display segment-routing ipv6 te policy status
display segment-routing ipv6 te policy-group
display segment-routing ipv6 te sbfd
display segment-routing ipv6 te segment-list
display segment-routing ipv6 te source-sid
display segment-routing label-block
display segment-routing mapping-server prefix-sid-map
display session aging-time application
display session aging-time state
display session relation-table
display session statistics
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table ipv4
display session table ipv6
display session table multicast ipv4
display sftp client source
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display sriov-vf-pciaddr
display ssh client server-public-key
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display stop-accounting-buffer (for RADIUS)
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display stun client info
display stun server packet-statistics
display supervlan
display system stable state
display system-working-mode
display te link-management bandwidth-allocation
display te link-management srlg
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver alarm
display transceiver diagnosis
display transceiver interface
display transceiver itu-channel
display transceiver manuinfo
display ttl-security statistics
display tunnel flow-statistics
display tunnel-bundle
display tunnel-info ipv6
display tunnel-interface
display tunnel-policy
display udp-helper interface
display user-group
display user-interface
display userlog export
display user-profile
display users
display vam client fsm
display vam client shortcut interest
display vam client shortcut ipv6 interest
display vam client statistics
display vam server address-map
display vam server ipv6 address-map
display vam server ipv6 private-network
display vam server private-network
display vam server statistics
display vcpu-pool
display version
display version-update-record
display vlan
display vlan brief
display vlan-group
display vmem-pool
display vpn-peer
display vrrp
display vrrp binding
display vrrp ipv6
display vrrp ipv6 statistics
display vrrp statistics
display vxlan tunnel
display waas class
display waas policy
display waas session
display waas statistics dre
display waas status
display waas tfo auto-discovery blacklist
display web-cache
display web-redirect rule
distribute
distribute bgp-ls
distribute bgp-ls
distribute bgp-ls
distributed-gateway local
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp unidirectional-shutdown
dns domain
dns dscp
dns proxy enable
dns server
dns source-interface
dns spoofing
dns trust-interface
dns-flood action
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood threshold
dns-list
dns-server
docker
docker-config reload
domain
domain default enable
domain if-unknown
domain-authentication send-only
domain-authentication-mode
domain-distinguisher
domain-id (OSPF view)
domain-id (OSPFv3 view)
domain-name
domain-name
dot1p-priority (IGMP-snooping view)
dot1p-priority (MLD-snooping view)
dot1q ethernet-type
dot1x
dot1x authentication-method
dot1x auth-fail vlan
dot1x critical vlan
dot1x critical-voice-vlan
dot1x domain-delimiter
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant url
dot1x guest-vlan
dot1x handshake
dot1x handshake reply enable
dot1x handshake secure
dot1x mandatory-domain
dot1x max-user
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x timer
dot1x unicast-trigger
dpd
dpd
drop-upon-invalid
dscp
dscp
dscp
dscp
dscp
dscp
ds-lite enable
ds-te bc-model
ds-te mode
ds-te te-class
dumb-time
duplex
dynamic (SRv6 TE policy path preference view)
dynamic (SRv6 TE-ODN view)
dynamic-flow aging-time
E
e1 channel-set
e1 clock
e1 flag
e1 frame-format
e1 loopback
e1 shutdown
e1 unframed
ebgp-interface-sensitive
email
email parameter-profile
embedded-rp
enable
enable
enable (IGMP-snooping view)
enable (MLD-snooping view)
enable ipsec-profile
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encap-data-enable
encapsulation eth out-interface
encapsulation ipv4 nexthop
encapsulation ipv6 nexthop
encapsulation source-address
encapsulation-mode
encapsulation-mode encaps include local-end.x
encapsulation-mode encaps reduced
encoding
encryption
encryption-algorithm
end-point
entry-limit (IGMP-snooping view)
entry-limit (MLD-snooping view)
escape-key
esn enable
esp authentication-algorithm
esp encryption-algorithm
event cli
event hotplug
event interface
event process
event snmp oid
event snmp-notification
event syslog
event track
event-log
event-log
evpn df-election algorithm (interface view)
evpn df-election algorithm (system view)
evpn df-election preference
evpn df-election preference non-revertive
evpn encapsulation
evpn encapsulation srv6
evpn frr remote
evpn irb asymmetric
evpn route arp-mobility suppression
evpn route mac-mobility suppression
evpn sdwan routing-enable
exception filepath
exchange-mode
exclude-attribute (MAC binding server view)
exclude-attribute (portal authentication server view)
exempt acl
exit
exit()
expect { data | hex-data }
expect { failed-data | hex-failed-data }
expect failed-status
expect ip
expect ipv6
expect status
expect-bandwidth
expired
explicit segment-list
explicit-path
export
export route-policy
export route-policy
export route-policy
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
F
fast-leave (IGMP-snooping view)
fast-leave (MLD-snooping view)
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute enable
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
fast-reroute mirror delete-delay
fast-reroute mirror enable
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
fast-reroute route-policy
fast-reroute tiebreaker
fast-reroute tiebreaker (Flexible algorithm view)
fast-reroute tiebreaker (IS-IS IPv4 unicast address family view/IS-IS IPv6 unicast address family view)
fast-reroute ti-lfa
fast-reroute ti-lfa
fast-reroute ti-lfa enable
fast-reroute timer
fdisk
feature
fib lifetime
file prompt
file-directory
filename
filter
filter
filter
filter-policy export
filter-policy import
fin-flood action
fin-flood detect
fin-flood detect non-specific
fin-flood threshold
fixdisk
flag
flag
flag c2
flag j0
flag j1
flash-flood
flex-algo
flex-algo algorithm
flooding disable (VSI view)
flow
flow
flow (analyzer AMS view)
flow (collector instance view)
flow priority-based-schedule bandwidth-threshold
flow priority-based-schedule enable
flow priority-based-schedule schedule-period
flow-control
flow-control
flow-interval
flow-route (Flowspec IPv4 address family view, Flowspec IPv6 address family view)
flow-route (system view)
flow-route ipv6
flowspec
flush suboptimal-route
forbidden-ip
forbidden-ip-range
format
fqdn
frame-format
frame-format
frame-format (CE1 interface)
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free ssh
free user-interface
free-traffic threshold
frequency
frequency-adjustment
ftn enable
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server ssl-server-policy
ftp timeout
full-name
G
gateway subnet
gateway vsi-interface
gateway-list
gateway-list
gateway-list
get
get
global-block
global-ip-pool
global-parameter enable
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart peer-reset
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
group
group
group-filter
group-policy (IGMP-snooping view)
group-policy (MLD-snooping view)
grpc data-model
grpc enable
grpc idle-timeout
grpc log dial-in gnmi
grpc log dial-in rpc
grpc log dial-out
grpc pki domain
grpc port
gts
gts percent
gunzip
gzip
H
header
hello interval
hello lost
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
help
hex-data-fill
high-performance-mode
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host-advertise
host-aging-time (IGMP-snooping view)
host-aging-time (MLD-snooping view)
hostname
hostname
host-route
hotkey
http acl
http enable
http ipv6 acl
http method
http-flood action
http-flood detect
http-flood detect non-specific
http-flood port
http-flood threshold
http-method
http-redirect ssl-server-policy
https acl
https ipv6 acl
hub ipv6 private-address
hub private-address
hub-group
hwtacacs nas-ip
hwtacacs scheme
I
icmp-flood action
icmp-flood detect ip
icmp-flood detect non-specific
icmp-flood threshold
icmpv6-flood action
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood threshold
ict mode enable
identity
identity local
idle-timeout
ifconfig
ifit enable
if-match
if-match
if-match
if-match
if-match
if-match acl
if-match acl
if-match mpls-exp
if-match packet-length
if-match second-mpls-exp
if-match source-ip
if-match temp-pass
ifmonitor crc-error
ifmonitor input-error
ifmonitor input-usage
ifmonitor output-error
ifmonitor output-usage
ifmonitor rx-pause
ifmonitor sdh-b1-error
ifmonitor sdh-b2-error
ifmonitor sdh-error
ifmonitor tx-pause
igmp
igmp enable
igmp fast-leave
igmp group-policy
igmp last-member-query-count
igmp last-member-query-interval
igmp max-response-time
igmp other-querier-present-interval
igmp proxy enable
igmp proxy forwarding
igmp query-interval
igmp robust-count
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp version
igmp-snooping
igmp-snooping dot1p-priority
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping version
ignore all-peers
ignore-att
ignore-first-as
igp sync delay
igp sync delay on-restart
ike address-group
ike compatible-gm-main enable
ike compatible-sm4 enable
ike dpd
ike gm-main sm4-version
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike logging negotiation enable
ike nat-keepalive
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
ikev2 address-group
ikev2 cookie-challenge
ikev2 dpd
ikev2 ipv6-address-group
ikev2 keychain
ikev2 nat-keepalive
ikev2 policy
ikev2 profile
ikev2 proposal
ikev2-profile
import
import
import bgp
import evpn mac-ip
import route-policy
import route-policy
import route-policy
import-route
import-route
import-route
import-route
import-route
import-route
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
import-route limit
import-route sr-policy
import-route-append
import-source
inclusive-tunnel dynamic
index
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center filter
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
in-group
init-ttl
inner-type ipv4
inqa analyzer
inqa collector
inqa mp
inside ip
inside-vpn
inside-vrf
instance
instance
instance
instance (analyzer view)
instance (collector view)
integrity
interface
interface bridge-aggregation
interface dialer
interface loopback
interface mp-group
interface null
interface policy deny
interface pos
interface range
interface range name
interface route-aggregation
interface serial
interface tunnel
interface tunnel-bundle
interface virtual-eth-group
inter-protocol fast-reroute
interval
Interval
ip
ip
ip (MAC binding server view)
ip (portal authentication server view)
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address ppp-negotiate
ip address unnumbered
ip binding vpn-instance
ip fast-forwarding load-sharing
ip global policy-based-route
ip host
ip http preflight enable
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip last-hop hold
ip link set
ip link show
ip local policy-based-route
ip netstream
ip netstream aggregation
ip netstream aging
ip netstream export host
ip netstream export rate
ip netstream export source
ip netstream export template refresh-rate
ip netstream export version
ip netstream filter
ip netstream ipsec raw-packet
ip netstream max-entry
ip netstream mpls
ip netstream outbound sampler srv6-policy
ip netstream outbound srv6-policy
ip netstream sampler
ip netstream template rfc7011
ip netstream timeout active
ip netstream timeout inactive
ip netstream vxlan udp-port
ip pool
ip pool gateway
ip public-instance
ip route-static
ip route-static arp-request
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip route-static vpn-instance
ip route-static-group
ip rpf-route-static
ip source binding (interface view)
ip urpf
ip verify source
ip vpn-instance (BGP instance view)
ip vpn-instance (system view)
ip-in-use threshold
ips apply policy
ips capture-cache
ips parameter-profile
ips policy
ips signature auto-update
ips signature auto-update-now
ips signature import snort
ips signature remove snort
ips signature rollback
ips signature update
ips signature update-log
ips whitelist
ips whitelist activate
ips whitelist enable
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec fragmentation
ipsec global-df-bit
ipsec limit max-tunnel
ipsec logging negotiation enable
ipsec logging packet enable
ipsec no-nat-process enable
ipsec profile
ipsec redundancy enable
ipsec sa global-duration
ipsec sa global-soft-duration buffer
ipsec sa idle-time
ipsec transform-set
ipv4-address
ipv6
ipv6 (portal authentication server view)
ipv6 accept-label
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 advertise-label
ipv6 bandwidth-based-sharing
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp relay source-address
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping alarm enable
ipv6 dhcp snooping alarm threshold
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check relay-forward
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping client-detect
ipv6 dhcp snooping deny
ipv6 dhcp snooping enable
ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping pd binding record
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 extension-header drop enable
ipv6 fast-forwarding load-sharing
ipv6 global policy-based-route
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 receive enable
ipv6 icmpv6 send enable
ipv6 icmpv6 source
ipv6 import bgp
ipv6 last-hop hold
ipv6 local policy-based-route
ipv6 lsp-trigger
ipv6 mtu
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd mac-check enable
ipv6 nd mode uni
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd online-offline-log enable
ipv6 nd ra boot-file-url
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix default
ipv6 nd ra router-lifetime
ipv6 nd route-direct advertise
ipv6 nd route-direct prefix convert-length
ipv6 nd router-preference
ipv6 nd scan auto enable
ipv6 nd scan auto send-rate
ipv6 nd unsolicited-na-learning enable
ipv6 nd user-ip-conflict record enable
ipv6 nd user-move record enable
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbor timer stale-aging
ipv6 neighbors max-learning-num
ipv6 netstream
ipv6 netstream aggregation
ipv6 netstream export host
ipv6 netstream export rate
ipv6 netstream export source
ipv6 netstream export template refresh-rate
ipv6 netstream export version
ipv6 netstream filter
ipv6 netstream max-entry
ipv6 netstream outbound sampler srv6-policy
ipv6 netstream outbound srv6-policy
ipv6 netstream sampler
ipv6 netstream timeout active
ipv6 netstream timeout inactive
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim
ipv6 pim bfd enable
ipv6 pim bsr-boundary
ipv6 pim dm
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim holdtime join-prune
ipv6 pim neighbor-policy
ipv6 pim non-stop-routing
ipv6 pim passive
ipv6 pim require-genid
ipv6 pim sm
ipv6 pim state-refresh-capable
ipv6 pim timer graft-retry
ipv6 pim timer hello
ipv6 pim timer join-prune
ipv6 pim triggered-hello-delay
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 prefer temporary-address
ipv6 prefix
ipv6 reassemble local enable
ipv6 redirects enable
ipv6 route fast-switchover enable
ipv6 router-renumber enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 route-static vpn-instance
ipv6 source binding (interface view)
ipv6 temporary-address
ipv6 unreachables enable
ipv6 urpf
ipv6 verify source
ipv6 virtual-reassembly enable
ipv6-address
isis
isis adjacency-sid
isis affinity flex-algo
isis authentication send-only
isis authentication-mode
isis bfd enable
isis bfd session-restrict-adj
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis fast-reroute ti-lfa disable
isis ipv6 bfd enable
isis ipv6 bfd session-restrict-adj
isis ipv6 cost
isis ipv6 enable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 fast-reroute ti-lfa disable
isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
isis ipv6 tag
isis link-delay
isis link-quality adjust-cost
isis member-port adjacency-sid
isis mesh-group
isis mib-binding
isis peer hold-max-cost duration
isis peer-ip-check
isis prefix-sid
isis prefix-suppression
isis primary-path-detect bfd
isis silent
isis small-hello
isis tag
isis timer csnp
isis timer hello
isis timer holding-multiplier
isis timer lsp
isis timer retransmit
is-level
is-name
is-name map
isolate enable
isolate enable
isolate enable
isolate enable
ispf enable
ispf enable
itu-channel
J
jitter threshold
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
jumboframe enable
jumboframe enable
K
keepalive
keepalive
keep-multiplier
key
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain
keychain
key-string
kubelet enable
L
l2vpn enable
l2vpn enable
l2vpn enable
l2vpn log enable
l2vpn log enable
l2vpn switchover
l2vpn switchover
l3-vni
label-allocation-mode
label-distribution
labeled-route ignore-no-tunnel
lacp default-selected-port disable
lacp edge-port
lacp mode
lacp period short
lacp system-priority
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-snooping view)
lcd
ldap attribute-map
ldap scheme
ldap server
ldap-server
license activation-file install
license activation-file uninstall
license activation-key install
license activation-key uninstall
license client config cache
license client enable
license client username
license compress
license compress
license license-key install
license license-key uninstall
license server
limit
line
line class
link-aggregation bfd
link-aggregation bfd-compatible enable
link-aggregation global load-sharing mode
link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mpls enhanced
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
link-delay
link-flap protect enable
link-management periodic-flooding timer
link-protocol
link-protocol
link-protocol hdlc
link-protocol ppp
link-quality probe interval
link-select delay
link-select suppress-period
listen-port
load-balance per-packet enable
load-balance per-session periodic-adjust adjust-interval
load-balance per-session periodic-adjust enable
load-balance per-session periodic-adjust threshold
load-splitting (IPv6 MRIB view)
load-splitting (MRIB view)
local-address
local-block
local-guest email format
local-guest email sender
local-guest email smtp-server
local-guest generate
local-guest manager-email
local-guest send-email
local-guest timer
local-identity
local-ip-address
locality
local-proxy-arp enable
local-proxy-nd enable
local-server log change-password-prompt
local-user
local-user-export class network
local-user-export class network guest
local-user-import class network
local-user-import class network guest
locator
lock
lock reauthentication
lock-key
log
log data-group-reuse
log enable
logfile save
login-dn
login-password
logout-notify
log-peer-change
log-peer-change
log-peer-change
log-peer-change
log-route-flap
longest-match (IPv6 MRIB view)
longest-match (MRIB view)
loopback
loopback
loopback
loopback (CE1 interface)
loopback-detection action
loopback-detection enable
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
loopback-test
loop-detect
loss-measure alarm
loss-measure enable continual
loss-measure enable duration
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac-address
mac-address
mac-address
mac-address (interface view)
mac-address (system view)
mac-address mac-learning enable
mac-address static vsi
mac-advertising disable
mac-authentication
mac-authentication access-user log enable
mac-authentication authentication-method
mac-authentication carry user-ip
mac-authentication domain
mac-authentication host-mode
mac-authentication max-user
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer (interface view)
mac-authentication timer (system view)
mac-authentication user-name-format
mac-learning enable
mac-vlan enable
mac-vlan mac-address
mac-vlan trigger enable
mailbox
mail-domain-name
mail-protocol
map
match local (IKEv2 profile view)
match local address (IKE keychain view)
match local address (IKE profile view)
match local address (IKEv2 policy view)
match remote
match remote
match tcp
match vrf (IKEv2 policy view)
match vrf (IKEv2 profile view)
max-failure
maxhops
maximum load-balancing
max-response-time (IGMP view)
max-response-time (IGMP-snooping view)
max-response-time (MLD view)
max-response-time (MLD-snooping view)
md5-authentication
md5sum
mdix-mode
measure enable
measure enable (analyzer instance view)
measure mode
member interface
memory
memory-threshold
memory-threshold usage
method
metric-bandwidth advertisement enable
metric-bandwidth suppression
metric-delay advertisement enable
metric-delay suppression
metric-type
mirror remote-sid delete-delay
mirroring-group
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirror-to interface
mkdir
mkdir
mkdir
mld
mld enable
mld fast-leave
mld group-policy
mld last-listener-query-count
mld last-listener-query-interval
mld max-response-time
mld non-stop-routing
mld other-querier-present-timeout
mld proxy enable
mld proxy forwarding
mld query-interval
mld robust-count
mld startup-query-count
mld startup-query-interval
mld static-group
mld version
mld-snooping
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping version
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor resend cpu-usage
monitor resend cpu-usage core-interval
monitor thread
more
mount
move
mp
mpls bandwidth-based-sharing
mpls bfd (for LSP)
mpls bfd (for TE tunnel)
mpls bfd backup detect-multiplier
mpls bfd backup min-receive-interval
mpls bfd backup min-transmit-interval
mpls bfd detect-multiplier
mpls bfd enable
mpls bfd min-receive-interval
mpls bfd min-transmit-interval
mpls enable
mpls forwarding split-horizon
mpls label advertise
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp ipv6 enable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls lsr-id
mpls mtu
mpls periodic-tracert (for LSP)
mpls statistics
mpls statistics interval
mpls te
mpls te affinity-attribute
mpls te auto-tunnel backup disable
mpls te backup
mpls te backup affinity-attribute
mpls te backup bandwidth
mpls te backup hop-limit
mpls te backup-path
mpls te bandwidth
mpls te bandwidth change thresholds
mpls te bidirectional
mpls te delegation
mpls te enable
mpls te enable (interface view)
mpls te enable (IS-IS view)
mpls te enable (OSPF area view)
mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te hop-limit
mpls te igp advertise
mpls te igp metric
mpls te igp shortcut
mpls te link-attribute
mpls te loop-detection
mpls te max-link-bandwidth
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
mpls te metric
mpls te path
mpls te path-metric-type
mpls te path-selection adjacency-sid
mpls te priority
mpls te record-route
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
mpls te reserved-for-binding
mpls te resv-style
mpls te retry
mpls te route-pinning
mpls te service-class
mpls te signaling
mpls te static-cr-lsp
mpls te static-sr-mpls
mpls te static-sr-mpls wtr
mpls te statistics
mpls te timer retry
mpls ttl expiration enable
mpls ttl propagate
mpls tunnel-bfd (for LSP)
mpls tunnel-bfd (for TE tunnel)
mpls tunnel-bfd detect-multiplier
mpls tunnel-bfd min-receive-interval
mpls tunnel-bfd min-transmit-interval
mpls tunnel-sbfd (for TE tunnel)
mpls-forwarding statistics prefix-list
mpls-simulation enable
msdp
mtrace v1
mtrace v2
mtrace-service port
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
multicast boundary
multicast routing
multicast rpf-proxy-vector compatible
multicast-vpn
multi-instance enable
multiplex mode
multi-topology
mvpn-advertise-rt-import
N
name
nas-id
nas-id bind
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nas-port-type
nas-port-type
nat address-group
nat alg
nat dns-map
nat hairpin enable
nat inbound
nat inbound rule move
nat log enable
nat log flow-active
nat log flow-begin
nat log flow-end
nat log port-block usage threshold
nat log port-block-assign
nat log port-block-withdraw
nat mapping-behavior endpoint-independent
nat outbound
nat outbound rule move
nat port-block flow-trigger enable
nat server (interface-based NAT)
nat server rule move
nat server-group
nat static enable
nat static inbound
nat static inbound net-to-net
nat static inbound rule move
nat static outbound
nat static outbound net-to-net
nat static outbound rule move
nat timestamp delete
nat-keepalive
nbns-list
nesting-vpn
netbios-type
netconf capability specific-namespace
netconf idle-timeout
netconf log
netconf soap acl
netconf soap domain
netconf soap enable
netconf soap http port
netconf ssh server enable
netconf ssh server port
network
network
network
network
network
network
network short-cut
network-entity
newer
nexthop
nexthop global-address-only
nexthop interface (BGP IPv4 SR next hop view/BGP-VPN IPv4 SR next hop view/BGP-VPN IPv4 EVPN SR next hop view)
nexthop interface (BGP SRv6 next hop view/BGP-VPN SRv6 next hop view/BGP-VPN IPv6 EVPN SR next hop view)
next-hop ip
next-hop ipv6
nexthop recursive-lookup delay
next-server
nextsid
nhop-only
nhrp authentication
nhrp holdtime
nhrp network-id
nhrp nhs
no-fragment enable
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
nqa
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
nqa twamp-light sender
nssa
nssa
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service cwmp unicast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service unicast-peer
ntp-service unicast-server
O
object
object-dir
oid
on-demand
opaque-capability enable
opcode
opcode end-am
opcode end-as
open
operation (FTP operation view)
operation (HTTP operation view/HTTPS template view)
optimize
option
option
option-group
organization
organization-unit
originating-rp
ospf
ospf adjacency-sid
ospf area
ospf authentication-mode
ospf bfd enable
ospf cost
ospf database-filter
ospf dr-priority
ospf fast-reroute lfa-backup
ospf fast-reroute remote-lfa disable
ospf fast-reroute ti-lfa disable
ospf link-quality adjust-cost
ospf lsu-flood-control
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf prefix-sid
ospf prefix-suppression
ospf primary-path-detect bfd
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospf ttl-security
ospfv3
ospfv3 area
ospfv3 authentication-mode
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 fast-reroute lfa-backup exclude
ospfv3 fast-reroute ti-lfa disable
ospfv3 ipsec-profile
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 prefix-suppression
ospfv3 primary-path-detect bfd
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
out interface
out-group
output-delay
output-delay
overflow-replace (IGMP-snooping view)
overflow-replace (MLD-snooping view)
overload adjust-cost
override-current
P
packet-capture interface
packet-capture local interface
packet-capture read
packet-capture stop
packet-filter
packet-filter default deny
packet-loss threshold
packet-rate
parity
passive
passthrough
password
password
password (device management user view)
password (network access user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control change-password first-login enable
password-control change-password weak-password enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
path link-type index preference
path sdwan
path-metric-type
path-mtu
path-mtu reserved
pce address
pce deadtimer
pce delegation
pce keepalive
pce passive-delegate report-only
pce peer delegation-priority
pce peer md5
pce redelegation-timeout
pce request-timeout
pce state-timeout
pce static
pce tolerance
pce-client
pcep (SRv6 TE policy path preference dynamic view)
pcep (SRv6 TE-ODN dynamic view)
pcep type
peer
peer
peer
peer
peer
peer
peer
peer
peer additional-paths
peer advertise additional-paths best
peer advertise encap-type sdwan
peer advertise encap-type srv6
peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
peer advertise vpn-reoriginate ibgp (BGP VPNv4 address family view)
peer advertise-community
peer advertise-ext-community
peer allow-as-loop
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer as-path-acl
peer bandwidth
peer bfd
peer bfd parameters
peer bmp server
peer capability-advertise conventional
peer capability-advertise orf non-standard
peer capability-advertise orf prefix-list
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer cluster-id
peer connect-interface
peer default-route-advertise
peer description
peer description
peer dscp
peer ebgp-max-hop
peer egress-engineering
peer egress-engineering srv6
peer enable
peer fake-as
peer filter-policy
peer flap-dampen
peer graceful-restart timer restart extra
peer group
peer ignore
peer ignore-first-as
peer ignore-originatorid
peer ipsec-profile
peer keep-all-routes
peer keychain
peer label-route-capability
peer log-change
peer low-memory-exempt
peer mesh-group
peer minimum-ttl
peer mpls-local-ifnet disable
peer next-hop-invariable
peer next-hop-invariable (BGP VPNv4 address family view)
peer next-hop-local
peer nexthop-recursive-policy disable
peer next-hop-vpn
peer next-hop-vpn
peer password
peer peer-set
peer peer-set
peer preferred-value
peer prefix-list
peer prefix-sid
peer public-as-only
peer reflect-client
peer reflect-nearby-group
peer re-originated
peer request-sa-enable
peer route-limit
peer route-mode
peer route-policy
peer route-update-interval
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer soo
peer source-address
peer substitute-as
peer tcp-mss
peer timer
peer timer connect-retry
peer ttl-security
peer upe
peer upe route-policy
peer validation-disable
peer validation-redirect-disable
peer-public-key end
period
permit interface
permit vlan
permit vpn-instance
pfs
phone
pic
pic
pic
pim
pim bfd enable
pim bsr-boundary
pim dm
pim neighbor-policy
pim passive
pim require-genid
pim sm
pim timer hello
ping
ping evpn vpls srv6
ping evpn vpws srv6
ping ipv6
ping ipv6-sid
ping mpls ipv4
ping mpls out-labels
ping mpls pw
ping mpls sr-policy
ping mpls te
ping srv6-te policy
pkcs7-encryption-algorithm
pki abort-certificate-request
pki certificate logging enable
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
policy
policy enable
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy-based-route
policy-group
port
port
port (MAC binding server view)
port (portal authentication server view)
port access vlan
port hybrid pvid
port hybrid vlan
port ifmonitor crc-error
port ifmonitor input-error
port ifmonitor output-error
port ifmonitor rx-pause
port ifmonitor sdh-b1-error
port ifmonitor sdh-b2-error
port ifmonitor sdh-error
port ifmonitor tx-pause
port lacp system-mac
port lacp system-priority
port link-aggregation group
port link-flap protect
port link-mode
port link-type
port pvid forbidden
port trunk permit vlan
port trunk pvid
portal { bas-ip | bas-ipv6 }
portal { ipv4-max-user | ipv6-max-user }
portal apply mac-trigger-server
portal apply web-server
portal auth-error-record enable
portal auth-error-record export
portal auth-error-record max
portal auth-fail-record enable
portal auth-fail-record export
portal auth-fail-record max
portal authorization strict-checking
portal cloud report interval
portal delete-user
portal device-id
portal domain
portal dual-ip enable
portal dual-stack enable
portal dual-stack traffic-separate enable
portal enable (interface view)
portal extend-auth domain
portal fail-permit server
portal fail-permit web-server
portal forbidden-rule
portal free-all except destination
portal free-rule
portal free-rule description
portal free-rule destination
portal free-rule source
portal ipv6 free-all except destination
portal ipv6 layer3 source
portal ipv6 user-detect
portal layer3 source
portal local-web-server
portal logout-record enable
portal logout-record export
portal logout-record max
portal max-user
portal nas-id profile
portal nas-port-id format
portal oauth authorization-vlan
portal outbound-filter enable
portal packet log enable
portal redirect log enable
portal redirect max-session per-user
portal refresh enable
portal roaming enable
portal safe-redirect default-action
portal safe-redirect enable
portal safe-redirect forbidden-file
portal safe-redirect forbidden-url
portal safe-redirect method
portal safe-redirect permit-url
portal safe-redirect user-agent
portal server
portal temp-pass enable
portal traffic-accounting disable
portal traffic-backup threshold
portal user log enable
portal user-block failed-times
portal user-block reactive
portal user-detect
portal user-dhcp-only
portal user-log traffic-separate
portal web-proxy port
portal web-server
port-block
port-detect enable
port-isolate enable
port-range
ppp access-user log enable
ppp account-statistics enable
ppp acfc local-request
ppp acfc remote-reject
ppp authentication-mode
ppp callback
ppp callback ntstring
ppp chap password
ppp chap user
ppp compression iphc enable
ppp compression iphc rtp-connections
ppp compression iphc tcp-connections
ppp ipcp dns
ppp ipcp dns admit-any
ppp ipcp dns request
ppp ipcp remote-address match
ppp ip-pool route
ppp lcp delay
ppp lcp echo mru verify
ppp lqm
ppp lqm lcp-echo
ppp mp
ppp mp binding-mode
ppp mp endpoint
ppp mp fragment disable
ppp mp lfi delay-per-frag
ppp mp lfi enable
ppp mp lfi size-per-frag
ppp mp load-sharing mode strict-round-robin
ppp mp max-bind
ppp mp min-bind
ppp mp min-fragment
ppp mp mp-group
ppp mp short-sequence
ppp mp soft-binding
ppp mp sort-buffer-size
ppp mp timer lost-fragment
ppp mp user
ppp mp virtual-template
ppp pap local-user
ppp pfc local-request
ppp pfc remote-reject
ppp timer negotiate
pppoe-client
pppoe-server access-delay
pppoe-server access-line-id bas-info
pppoe-server access-line-id circuit-id parse-mode
pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id content
pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id trust
pppoe-server bind
pppoe-server session-limit
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
pppoe-server tag ac-name
pppoe-server tag ppp-max-payload
pppoe-server tag service-name
pppoe-server throttle per-mac
pppoe-server virtual-template va-pool
prefer-cipher
preference
preference
preference
preference
preference
preference
preference
preferred-path
prefix
prefix-pool
prefix-priority
prefix-priority
prefix-suppression
prefix-suppression
pre-shared-key
pre-shared-key
pre-shared-key (ADVPN domain view)
pre-shared-key (VAM client view)
prf
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority
priority (IKE keychain view)
priority (IKE profile view)
priority (IKEv2 policy view)
priority (IKEv2 profile view)
priority 8021p
probe connect
probe count
probe flow
probe interval (application quality probe instance view)
probe interval (NQA link quality operation view)
probe packet-dscp
probe packet-interval
probe packet-number
probe packet-number
probe packet-timeout
probe port
probe sync-port
probe timeout
process core
proposal
proposal
protection dual-receive
protect-target
protocol
protocol
protocol inbound
protocol lifetime
protocol udp-port
protocol-version
proxy multipath (IGMP view)
proxy multipath (MLD view)
proxy peer-sid
proxy-arp enable
proxy-nd enable
proxy-nd span-segment enable
proxy-url
public-key dsa
public-key ecdsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key local export sm2
public-key peer
public-key peer import sshkey
public-key rsa
public-key sm2
push-mode
put
put
pv-limit
pw-class (auto-discovery cross-connect group view)
pw-class (auto-discovery VSI view)
pw-class (system view)
pwd
pwd
pwd
pw-redundancy
pw-redundancy
pwsignaling
pw-type
pw-type
python
python filename
Q
qemu-img create
qemu-img info
qinq enable
qinq ethernet-type (interface view)
qinq ethernet-type (system view)
qos apply policy (interface view, control plane view)
qos apply policy (user profile view)
qos apply policy global
qos car
qos carl
qos cq
qos cql default-queue
qos cql inbound-interface
qos cql local-precedence
qos cql protocol
qos cql protocol mpls exp
qos cql queue
qos cql queue serving
qos fifo queue-length
qos flow-interval
qos gts
qos lr
qos map-table
qos overhead layer
qos policy
qos pq
qos pql default-queue
qos pql inbound-interface
qos pql local-precedence
qos pql protocol
qos pql protocol mpls exp
qos pql queue
qos pre-classify
qos pre-classify
qos priority
qos reserved-bandwidth
qos rtpq
qos trust
qos wfq
qos wred dscp
qos wred enable
qos wred ip-precedence
qos wred weighting-constant
quality-policy
queue af
queue ef
queue sp
queue wfq
queue-length
R
radius attribute extended
radius dscp
radius dynamic-author server
radius nas-ip
radius scheme
radius session-control client
radius session-control enable
radius-server test-profile
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction checked-element two-way-delay
reaction checked-element two-way-jitter
reaction checked-element two-way-loss
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reboot
redirect
redirect ip recursive-lookup tunnel
redirect-url
redundancy replay-interval
reflect between-clients
reflect change-path-attribute
reflector cluster-id
refresh bgp
refresh interval
reget
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark dot1p
remark dscp
remark ip-precedence
remark local-precedence
remark mpls-exp
remark qos-local-id
remark second-mpls-exp
remark service-class
remark tunnel-dscp
remote address
remote address dhcp client-identifier
remote-address
remote-server
remote-server
remove
rename
rename
rename
repeat
report-aggregation (IGMP-snooping view)
report-aggregation (MLD-snooping view)
request-method
reserved vxlan
reset
reset acl counter
reset advpn ipv6 session
reset advpn ipv6 session statistics
reset advpn session
reset advpn session statistics
reset aft session
reset arp
reset arp detection statistics
reset arp snooping
reset arp source-mac statistics
reset arp suppression vsi
reset arp valid-check statistics
reset attack-defense policy flood
reset attack-defense statistics interface
reset attack-defense statistics local
reset bfd session statistics
reset bgp
reset bgp all
reset bgp bmp server statistics
reset bgp dampening
reset bgp flap-info
reset cfd dm one-way history
reset cfd tst
reset connection-limit statistics
reset counters controller cpos
reset counters controller e1
reset counters interface
reset counters interface hdlc-bundle
reset counters interface mp-group
reset counters interface pos
reset counters interface serial
reset counters interface virtual-access
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping binding
reset dhcp snooping drni-statistics
reset dhcp snooping packet statistics
reset diagnostic event-log
reset diagnostic result
reset dldp statistics
reset dns host
reset dot1x guest-vlan
reset dot1x statistics
reset ethernet statistics
reset exception context
reset flow-route statistics
reset http-redirect statistics
reset hwtacacs statistics
reset iFIT statistic
reset igmp group
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ikev2 sa
reset ikev2 statistics
reset ip fast-forwarding cache
reset ip netstream statistics
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ipsec sa
reset ipsec sdwan-sa
reset ipsec sdwan-statistics
reset ipsec sdwan-tunnel
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping drni-statistics
reset ipv6 dhcp snooping packet statistics
reset ipv6 dhcp snooping pd binding
reset ipv6 fast-forwarding cache
reset ipv6 l2-multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 neighbors
reset ipv6 netstream statistics
reset ipv6 pathmtu
reset ipv6 policy-based-route statistics
reset ipv6 router-renumber statistics
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset isis all
reset isis event-log graceful-restart
reset isis event-log lsp
reset isis event-log spf
reset isis packet
reset isis peer
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset l2-multicast fast-forwarding cache
reset l2vpn mac-address
reset l2vpn statistics pw
reset l2vpn statistics srv6-pw
reset lacp statistics
reset local-guest waiting-approval
reset logbuffer
reset mac-authentication statistics
reset mac-forwarding statistics
reset mgre session
reset mgre statistics
reset mld group
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset mpls ldp
reset mpls statistics
reset mpls statistics tunnel-interface
reset mpls te pce statistics
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset multicast routing-table
reset nat session
reset netconf service statistics
reset netconf session statistics
reset nhrp statistics
reset nqa twamp-light statistics
reset osi statistics
reset ospf event-log
reset ospf event-log hello
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospfv3 event-log
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset portal auth-error-record
reset portal auth-fail-record
reset portal logout-record
reset portal packet statistics
reset portal redirect statistics
reset portal safe-redirect statistics
reset ppp access-user
reset ppp packet statistics
reset pppoe-client
reset pppoe-client session packet
reset pppoe-server
reset pppoe-server packet statistics
reset qos policy advpn
reset qos policy control-plane
reset qos policy global
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rsvp authentication
reset rsvp statistics
reset saved-configuration
reset scheduler logfile
reset sdwan tte connection
reset segment-routing ipv6 te forwarding statistics
reset session relation-table
reset session statistics
reset session statistics multicast
reset session table
reset session table ipv4
reset session table ipv6
reset session table multicast
reset session table multicast ipv4
reset snmp-agent trapbuffer
reset stp
reset stun client statistics
reset stun server packet-statistics
reset ttl-security statistics
reset tunnel flow-statistics
reset udp-helper statistics
reset userlog flow export
reset vam client fsm
reset vam client ipv6 fsm
reset vam client statistics
reset vam server address-map
reset vam server ipv6 address-map
reset vam server statistics
reset version-update-record
reset vrrp ipv6 statistics
reset vrrp statistics
reset waas cache dre
reset waas statistics dre
reset waas tfo auto-discovery blacklist
resolve-target
resolve-type
resource-release { data-fill | hex-data-fill }
restart
restore factory-default
restore startup-configuration
restrict
retain local-label
retry
retry
retry interval
retry realtime-accounting
return
reverse-route dynamic
reverse-route preference
reverse-route tag
revertive
revertive
revision-level
rfc1583 compatible
rhelp
rib
rip
rip authentication-mode
rip bfd
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip output-delay
rip poison-reverse
rip primary-path-detect bfd
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng ipsec-profile
ripng metricin
ripng metricout
ripng output-delay
ripng poison-reverse
ripng primary-path-detect bfd echo
ripng split-horizon
ripng summary-address
rir
rir backup
rir collaboration-link-group
rir link-type index
rir role
rir sdwan
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
role
role default-role enable
role feature-group
root-certificate fingerprint
route add
route del
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher (EVPN instance view)
route-distinguisher (public instance view)
route-mode adj-rib-in
route-mode adj-rib-out
route-mode loc-rib
route-option bypass-route
router id
router id
router-aging-time (IGMP-snooping view)
router-aging-time (MLD-snooping view)
route-rate-limit
route-replicate (public instance IPv4 address family view)
route-replicate (public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
route-replicate enable
router-id
router-id
router-id (BGP instance view)
router-id (BGP-VPN instance view)
router-id filter
route-select delay
route-tag (OSPF view)
route-tag (OSPFv3 view)
route-tag-check enable
route-update-delay
route-update-interval withdrawn enable
routing-table limit
routing-table limit
rpf proxy vector
rpm
rr-filter
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rstatus
rst-flood action
rst-flood detect
rst-flood detect non-specific
rst-flood threshold
rsvp
rsvp authentication challenge
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
rsvp bfd enable
rsvp enable
rsvp hello enable
rsvp reduction retransmit increment
rsvp reduction retransmit interval
rsvp reduction srefresh
rtm cli-policy
rtm environment
rtm scheduler suspend
rtm tcl-policy
rule
rule
rule
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule comment
rule-logic
run bash
running-time
S
sa df-bit
sa duration
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa soft-duration buffer
sa spi
sa string-key
sa trigger-mode
sampler
save
sbfd
sbfd detect-multiplier
sbfd enable
sbfd min-receive-interval
sbfd min-transmit-interval
scan detect
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp client ipv6 source
scp client source
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
scramble
screen-length
screen-length disable
sdwan device-id
sdwan encapsulation global-udp-port
sdwan encapsulation udp-port
sdwan interface-id
sdwan keepalive
sdwan routing-domain
sdwan server
sdwan server enable
sdwan server port
sdwan site-id
sdwan site-name
sdwan site-role
sdwan ssl-client-policy
sdwan ssl-server-policy
sdwan system-ip
sdwan transport-network
sdwan vn-id
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
second-dot1q
security acl
security-logfile save
segment-list
segment-routing
segment-routing adjacency enable
segment-routing global-block
segment-routing ipv6 (system view)
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 best-effort
segment-routing ipv6 egress-engineering locator
segment-routing ipv6 end-x delete-delay
segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
segment-routing ipv6 locator (IS-IS IPv6 address family view)
segment-routing ipv6 locator (OSPFv3 process view)
segment-routing ipv6 traffic-engineering
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing member-port adjacency enable
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
segment-routing mpls
segment-routing sr-prefer
selective-flooding mac-address
selective-tunnel delay
selective-tunnel dynamic
select-seq load-balance-number
send
send-lifetime
sensor path
sensor-group (subscription view)
sensor-group (telemetry view)
sequencing
server
server connect-interface
server enable
server enable
server password
server primary
server secondary
server source-address
server vpn-instance
server-block-action (HWTACACS view)
server-detect (portal authentication server view)
server-detect (portal Web server view)
server-detect url
server-register
server-timeout
server-type (MAC binding server view)
server-type (portal authentication server view/portal Web server view)
server-verify enable
service
service
service
service
service
service-class
service-class
service-type (ISP domain view)
service-type (local user view)
session
session log bytes-active
session log enable
session log packets-active
session log time-active
session persistent acl
session protection
session statistics enable
session-time include-idle-time
set authentication password
set vcpu-pool
set vmem-pool
set-att
set-overload
severity-level (IPS policy view)
severity-level (IPS signature view)
sfc diffserv-mode
sfc ttl-mode
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
sham-link (OSPF area view)
sham-link (OSPFv3 area view)
shell
shortcut interest
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (MSDP view)
shutdown process
shutdown process
shutdown process
shutdown process
shutdown-interval
sid
signaling-protocol
signature
signature { large-icmp | large-icmpv6 } max-length
signature detect
signature level action
signature level detect
signature override
signature override all
signature-id
silent-interface
silent-interface
silent-interface
sip-server
site
site
sla
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp trap rate-limit
snmp virtual-access visible
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent packet response dscp
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable { b1-tca | b2-tca | b3-tca }
snmp-agent trap enable arp
snmp-agent trap enable bfd
snmp-agent trap enable bgp
snmp-agent trap enable ifmonitor
snmp-agent trap enable ike
snmp-agent trap enable ipsec
snmp-agent trap enable isis
snmp-agent trap enable l2vpn
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable mac-address
snmp-agent trap enable mpls
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable pim
snmp-agent trap enable pim6
snmp-agent trap enable radius
snmp-agent trap enable srv6-policy
snmp-agent trap enable stp
snmp-agent trap enable syslog
snmp-agent trap enable te
snmp-agent trap enable vrrp
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap periodical-interval
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp unicast-server
source
source
source
source interface (ICMP echo/UDP tracert operation view)
source interface (TWAMP Light client-session view)
source ip
source ipv6
source mac
source port
source-address
source-address (IPS whitelist entry view)
source-address (user-defined IPS signature rule view)
source-deny (IGMP-snooping view)
source-deny (MLD-snooping view)
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-policy (IPv6 PIM view)
source-policy (PIM view)
source-port
speed
speed
spf-schedule-interval
spoke ipv6 private-address
spoke private-address
sponsor-department
sponsor-email
sponsor-full-name
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
sr-policy steering
srv6 compress enable (IS-IS IPv6 address family view)
srv6 compress enable (SRv6 view)
srv6 igp metric
srv6 igp shortcut
srv6-policy alarm-threshold
srv6-policy autoroute enable
srv6-policy backup hot-standby enable
srv6-policy bfd echo
srv6-policy encapsulation-mode encaps include local-end.x
srv6-policy encapsulation-mode encaps reduced
srv6-policy forwarding statistics enable
srv6-policy forwarding statistics interval
srv6-policy locator
srv6-policy log enable
srv6-policy pce delegation enable
srv6-policy pce passive-delegate report-only enable
srv6-policy sbfd
srv6-policy switch-delay delete-delay
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server key-re-exchange enable
ssh server pki-domain
ssh server port
ssh server rekey-interval
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
standby auto-update config
standby routing-group
standby routing-group rule
standby timer routing-disable
start (TWAMP Light sender view)
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state
state (ISP domain view)
state (local user view)
state primary
state secondary
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
static-bind
static-bind
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
static-sr-mpls adjacency
static-sr-mpls lsp
static-sr-mpls prefix
statistics enable
statistics enable (cross-connect PW view)
statistics hold-time
statistics interval
statistics max-group
statistics signature-hit enable
statistics-interval
status
status
step
stop (TWAMP Light sender view)
stopbits
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp ignore-pvid-inconsistency
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp priority
stp pvst-bpdu-protection
stp region-configuration
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
stub
stub
stub-router
stub-router
stun client
stun server
sub-interface rate-statistic
subject-dn
subscription
subvlan
summary
summary
summary automatic
super
super authentication-mode
super default role
super password
supervlan
syn-ack-flood action
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood threshold
syn-flood action
syn-flood detect
syn-flood detect non-specific
syn-flood threshold
sysname
system
system-working-mode
T
tar create
tar extract
tar list
targeted-peer
targeted-peer
target-only
tclquit
tclsh
tcp anti-naptha enable
tcp state
tcp-algorithm-id
tcp-kind
tcp-port
te attribute enable
te attribute enable
te link-attribute
te metric
te srlg
telemetry
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server port
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
te-router-id
test-session (TWAMP Light client view)
test-session (TWAMP Light responder view)
test-session bind interface
te-subtlv
tfc enable
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold
threshold
threshold { b1-tca | b2-tca | b3-tca }
threshold percentage
threshold weight
time at
time once
time repeating
timer
timer connect-retry
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer keepalive
timer lsp-arrival
timer lsp-flood suppress-flapping
timer lsp-generation
timer lsp-generation suppress-flapping
timer lsp-max-age
timer lsp-refresh
timer purge-zero-lsp route-calculate-delay
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer route-calculate suppress-flapping
timer spf
timer triggered
timer triggered
time-range
timer-hold
timer-hold
timer-hold
timer-hold
timer-hold
timer-hold retry
timer-hold retry
timer-hold retry
timer-hold retry
timer-hold retry
timers
timers
timers removal unused
timestamp-format
tnl-policy
tos
tpa container enable
tpa data sync
tpa ip send-to-cpu
tpa ip source
tpa ipv6 send-to-cpu
tpa ipv6 source
tpa socket client-port-range
tpa socket server-port
tracert
tracert evpn vpls srv6
tracert evpn vpws srv6
tracert ipv6
tracert ipv6-sid
tracert mpls ipv4
tracert mpls out-labels
tracert mpls te
tracert srv6-te policy
track bfd
track interface
track interface physical
track interface protocol
track ip route reachability
track ipv6 route reachability
track list boolean
track list threshold percentage
track list threshold weight
track lldp neighbor
track nqa
traffic behavior
traffic classifier
traffic-engineering
traffic-policy
transform-set
transmit-pacing
transmit-pacing
trigger
ttl
ttl-mode
ttl-mode
ttl-security
tunnel
tunnel 6rd br
tunnel 6rd ipv4
tunnel 6rd prefix
tunnel accelerate
tunnel bfd enable
tunnel bfd enable echo
tunnel dfbit enable
tunnel discard ipv4-compatible-packet
tunnel flow-statistics enable
tunnel flow-statistics interval
tunnel global source-address
tunnel out-interface
tunnel path-mtu enable
tunnel protection ipsec
tunnel sid-list
tunnel tos
tunnel ttl
tunnel vpn-instance
tunnel-bfd enable
tunnel-bfd min-echo-receive-interval
tunnel-number
tunnel-policy (auto-discovery cross-connect view)
tunnel-policy (auto-discovery VSI view)
tunnel-policy (system view)
type
U
udp-flood action
udp-flood detect
udp-flood detect non-specific
udp-flood threshold
udp-helper broadcast-map
udp-helper enable
udp-helper multicast-map
udp-helper port
udp-helper server
umount
undelete
update schedule
update-first route-policy
url
url
url
url
url-parameter
usage
user
user
user-group
user-interface
user-interface class
userlog flow export host
userlog flow export load-balancing
userlog flow export source-ip
userlog flow export timestamp localtime
userlog flow export version
userlog flow syslog
username
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-password modify enable
user-profile
user-role
user-role
user-role
user-sync
using (CE1 interface)
V
valid class
validate-source-address
validity-datetime
vam client
vam client enable
vam client name
vam ipv6 client
vam server advpn-domain
vam server enable
vam server listen-port
vccv bfd
vccv cc
verbose
verify class
version
version
version
Version (HTTP/HTTPS operation view/HTTPS template view)
version (IGMP-snooping view)
version (MLD-snooping view)
version (SNMP DCA template view)
version disable
virsh attach-disk
virsh attach-interface
virsh attach-sriov
virsh autostart
virsh define
virsh define-by-cmd
virsh destroy
virsh detach-disk
virsh detach-interface
virsh detach-sriov
virsh domblklist
virsh domiflist
virsh dominfo
virsh edit
virsh list
virsh resume
virsh setmaxmem
virsh setmem
virsh setvcpus
virsh shutdown
virsh snapshot-create-as
virsh snapshot-current
virsh snapshot-delete
virsh snapshot-list
virsh snapshot-revert
virsh start
virsh suspend
virsh undefine
virsh vcpucount
virsh vcpuinfo
virsh vcpupin
virsh vncdisplay
virtual-system
vlan
vlan
vlan policy deny
vlan precedence
vlan-group
vlan-list
vlan-mapping modulo
vlan-termination broadcast enable
vlan-termination broadcast ra
vlan-type dot1q default
vlan-type dot1q untagged
vlan-type dot1q vid
vlan-type dot1q vid second-dot1q
vlink-peer
vlink-peer
vmm
voice-config
vpls-id
vpn popgo
vpn-id
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance policy deny
vpn-instance-capability simple (OSPF view)
vpn-instance-capability simple (OSPFv3 view)
vpn-peer
vpn-route cross multipath
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target
vrrp check-ttl enable
vrrp dot1q
vrrp dscp
vrrp ipv6 dot1q
vrrp ipv6 dscp
vrrp ipv6 isolate enable
vrrp ipv6 mode
vrrp ipv6 vrid
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp isolate enable
vrrp mode
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
vsi
vsi
vxlan
vxlan invalid-udp-checksum discard
vxlan local-mac report
vxlan tunnel arp-learning disable
vxlan udp-port
W
waas apply policy
waas asymmetric
waas class
waas config remove-all
waas config restore-default
waas dre cache aging
waas dre offset-step
waas policy
waas tfo auto-discovery blacklist enable
waas tfo auto-discovery blacklist hold-time
waas tfo base-congestion-window
waas tfo congestion-method
waas tfo connect-limit
waas tfo keepalive
waas tfo optimize dre
waas tfo optimize lz
waas tfo receive-buffer
web-cache
web-redirect url
wred
wred dscp
wred ip-precedence
X
xconnect vsi
xconnect vsi
xconnect-group
xml
Y
